Thread: Bathroom door rough-in
    DIY Junior Member joe59golfer's Avatar
    Jun 2009
    Missouri USA
    Default Bathroom door rough-in
    I'm installing a full bathroom in our basement in an odd space and need to put a door perpendicular to two walls. The space between the two walls is 34" with a triple stud on one side and a double on the other. I'd like to be able to get largest door in the space. I could go with nailing a single cripple stud through the face to the ends of these studs on both sides of the frame and end up with 31" rough opening, but is that sufficient support for an interior door? Thanks for the help.
    Plumber jimbo's Avatar
    A 31" rough will get you a 28" door..... not very big for a bathroom.
    In the Trades AZ Contractor's Avatar
    Apr 2007
    Phoenix, AZ
    Going to have to use a 28" door with narrow trim.
    Default door
    28" door, but the hallway will still be 34" so regular 2 1/2", or slimmer,trim would work.
