Hello, i have two problems, My Ac unit in my attic will not drain properly due to a clog in the 90 of the pvc pipe comming out of the unit(can't reach in to cut pvc). i was told to blow compressed air into the outlet(drain side, outside unit), but don't want it going farther into the unit.
since its plugged the water is comming out of the corner of the unit in to the overflow pan..
Also where can i get a emergency overflow pan?
im in Dallas TX, for anyone in the area.
i found a bigger pan but i'd like the same size as what is on it.
it is 25" x 54"
all i can find is 30" x 60"
thank you in advance for any help
Xfalcon
it is 25" x 54"
Xfalcon
