Results 1 to 13 of 13
Thread: Gooseneck Faucet dripping problem
Hybrid View
    Question Gooseneck Faucet dripping problem
    Can anyone give me advice - I have 2 new faucets with similar problems.
    I have a Franke high gooseneck kitchen faucet and after I turn the water off - it continues to drip for a while. When I remove the aerator - the excess water in the faucet pours out and then it's fine......until next time I use it.
    Is there anything I can do with this?
    Also - in my bathroom I have a Cifial high faucet - kind of an upside down L shape and there is always a drop of water hanging at the back of the faucet which, after quite a while, eventually drops off - to be replaced with another.
    The builder has told me that it is the shape of the faucets in both instances that causes this problem but I can't see how quality manufacturers like Franke and Cifial would allow this.
    Any help?
    thanks
    Plumber Cass's Avatar
    Nov 2005
    The builder may be right. If you remove the airators and let the water out and the dripping stops then it is just the water slowly dripping out.
    What leads you to believe that they are quality manufacturers?
    Dec 2007
    Quote Originally Posted by Cass View Post
    Just because you overpaid for a product does not mean it is quality...
    All it means is you are a Foo-Foo sucker....
    Well I'll be - why is everyone so nasty about what I wrote? I guess telling you I installed Herbeau in the other bathrooms will really tick you off.
    I actually went by the suggestion of the builders plumber but I suppose I should have known better than to trust someone in that field. Like trusting a car mechanic.................
    Thanks anyway - not a problem, if it irritates me that much, I'll just change them and toss these away.
    Default drip
    The problem is not the faucet it is the aerator. Air does not easily flow through an aerator into the spout and until air DOES enter the spout the water cannot drain out. Therefore, a little air goes in, and a little water drips out. The process speeds up a little the longer it lasts, but will take time. IF the aerator were at an angle so the water could drain from the bottom while air entered the top it would drain almost immediately.
    Plumber jimbo's Avatar
    Quote Originally Posted by dawnd3 View Post
    Your particular problem is related to the style/design of the faucet....a lot of water with no place to go. A similar design by another manufacturer may exhibit similar symptoms.
    Now, as to quality.... service plumbers have to deal everyday with problems involving high priced faucets made by brands that are not well supported in the maintenance area. Technical diagrams may or may not be available, parts may have to be ordered direct from the mfg, etc.
    On the one hand, we do not discount the axiom that you get what you pay for, but experience tells us that high-priced faucets sold at design studios do not guarantee quality or good engineering.
    Everyone has their favorite brand or brands, but there is a reason why plumbers have a preference for time-proven designs from the mainstream.......Delta, Moen, American Standard, Price Pfister, Chicago. And of course with that list, I have started a whole new debate!
    Dec 2007
    Nah Jimbo...
    I'll agree whole heartedly...
    You can get the Toyota that goes an easy 150-200K on scheduled routine maintenance at any good garage at a normal rate...
    Or, You can get the Ferrari which may need a bit more frequent tuning at a premium rate...
    I'll work on either...
    But on Foo-Foo I will guarantee that the additional PITA will be billable...
    It's your choice the water comes out the same temperature and flow rate whether it is a Delta or, a Herbeau...
    Just like the stoplights don't all turn green for a Ferrari, nor do the speed limit signs change.
    Your just paying a premium price for the same result...
    Of course you also might end up with a Hansa or, DeLorean type deal too...
    Gone... Kaput... Out of Business... Oh Shoot where do I find the parts...
    In the Trades kordts's Avatar
    Oct 2005
    exurban Chicago
    Wow,
    what a nerve, coming on to a plumbing website, getting free advice, and then ripping on plumbers. I really hope you paid a lot of money for those junk faucets.
    Dec 2007
    Quote Originally Posted by kordts View Post
    Wow,
    Ahhh go easy on her....
    She's just frustrated she got taken for a ride....
    Plunger/TurdPuncher kingsotall's Avatar
    Aug 2008
    Flagstaff, AZ Sitting on an upside down 5 gallon bucket next to the GO 68HD
    dawnd3, I believe HJ answered your question in his post. Hope that advice helps you. This forum is a helpful resource. Just gotta take the good with the bad. Your comments weren't in the least critical of plumbers. Take care.
    I just post cuz I like to see my avatar.
    Default faucets
    One other item. You may have purchased a $1,000 faucet, but in some cases, the actual working parts that wear out are the same ones that are in a $60 faucet, such as PricePfister, Central Brass, etc. In fact, when I come across that situation, I use the cheap parts rather than the same parts at a higher price from the third party manufacturer. You pay the extra money for a fancy spout and handles.
