Results 1 to 6 of 6
Thread: Grohe Shower head installation question
    DIY Member FlynHokie's Avatar
    Jan 2009
    Williamsburg, VA
    Default Grohe Shower head installation question
    I just installed the shower fixtures (grohe eurosmart) in our new tile shower.
    The little circle trim piece that goes around the shower downspout doesn't remain flush against the tile. Should I silicon it inplace, or is there another way to keep it flush?
    Thanks much.
    Jan 2009
    Williamsburg, VA
    Any suggestions out there? Thanks much :-)
    Jun 2009
    Penticton, BC
    Quote Originally Posted by FlynHokie View Post
    How much is it out? If it's just a little bit I wouldn't do anything about it and if I did I'd probably just use some clear silicone.
    If you want to stick the escutcheon to the tile then use some Dapp! But use it sparingly as it's very tacky and on tiles sometimes it can be tough get get completely off.
    Aug 2008
    Or just take the pipe back out, bend the escutcheon tabs back down so the pipe has to force it's way in and "tape and dope" the threads and screw it back in.
    I just post cuz I like to see my avatar.
    Jan 2009
    Williamsburg, VA
    It rests about 1/8" off tile, unless I hold it against tile. I never noticed tabbs. I'll look at that prior to silicon or Dapp.
    thanks much y'all! Bathroom is nearly done. Toilet flange instal today, counter/sink & light install today. shower door on Tuesday, then when I get home on Friday, medicine cabinet, towell racks and toilet paper holder, and Finished! WOOT!
    Many of those trim pieces come with little tabs that fit against the pipe to give a little friction that holds it in place.
