Thread: Toilet Flange installation
    DIY Member FlynHokie's Avatar
    Jan 2009
    Williamsburg, VA
    Default Toilet Flange installation
    I am getting ready to install the toilet flange, and I want to make sure it is oriented correctly.
    How should the two slotted holes that connect the bolts to the toilet be oriented relative to the wall? Should the center of both those holes be equidistant to the wall, the end of the holes, or the beginning of the holes?
    Thanks much!
    FlynHokie.
    As long as the smaller sections of the keyways are place at the rough-in from the wall, it makes no difference. If the bolts are keyed in place and will stay that way, it makes no difference if they are at the beginning or end of the slot. Adjust as you see fit.
    I consider myself an accomplished DIY'er. I don't know everything but help where I can. I'm not a pro, but like to think I'm professional.
    I like to turn the flange so that the bolts go completely to the far end of the slots. Then I use an extra nut on the bolts to hold them tight and perpendicular to the flange. This makes for an easier time setting the toilets. I suppose it isn't absolutely critical that the bolts go that far in the slot, but I do want the bolt heads away from the key area to make sure they don' pull out.
    Feb 2005
    Omaha, NE
    Some plumbers, I've been told, avoid using the long slots and instead use the other keyed openings which are just wide enough for the bolt and are open on the outside of the flange.
