Results 1 to 7 of 7
Thread: Need Help Identifying Tub Faucet, Delta ScaldGuard
    Default Need Help Identifying Tub Faucet, Delta ScaldGuard
    I want to replace the faceplate -as it has been leaking, and the knob -because it gets nasty mildew behind it. I've purchased two kits and neither matched. It looked like a Delta knob, but our other shower still has the button and it just has an arrow on it, no name. Can anyone help me identify this brand? Just a last ditch effort before we have the plumber rip out several tiles to replace all the workings behind the wall.
    http://www2.snapfish.com/slideshow/A...93619_28393619
    Not sure if these links will work. Please reply if they don't.
    Default faucet
    Delta ScaldGuard.
    Default Replacement Handle Options?
    Great but is there a replacement handle that will fit other than that yucky clear plastic one?
    Default faucet
    There are a lever, and a metal round one, normally used in hospital settings, but available at some parts stores or as a special order.
    Plumber jimbo's Avatar
    That was a 1600 series. Not a long-lived model. I don't think Delta has any trim parts any more. Aftermarket stuff is available, but variety is slim.
    DIY Junior Member ClassicTVMan1981's Avatar
    Mar 2013
    Milwaukie, OR, US
    Right... this was the old Delta-Mix 1600 series valve from the mid 1970s-'80s. These could be had with or without Scald-Guard depending on the stem valve used (use RP2090 stop stem for Scald-Guard applications).
    My 1985 Delta Faucet Canada catalog shows this model with this escutcheon variation, although our versions (the domestic, or U.S., market) are more or less similar to the Canadian market ones. The 1989 and later 1600s used the round 600-series escutcheons until being discontinued in 1993 in favor of the 1300 series, although since 1989 these models were supplanted by the new 1500-series Monitor valves.
    The 9/1978 printing of the official Delta Faucet Genuine Parts catalog shows the following models applied to this escutcheon design:
    Part no. RP3501: models 1702/1704, 1712/1714, 1722/1724 and 1746/1748
    Part no. RP3502: models 1802/1804, 1812/1814, 1822/1824 and 1846/1848
    Part no. RP3543: models 1602/1604, 1612/1614, 1622/1624 and 1646/1648
    Part no. RP4100 (with push-button diverter): models 1606/1608, 1636/1638
    ~Ben
    "Scaldguard" valves also had a pressure balancing spool in the body to the right of the handle, which is what made them "scald guard".
