Results 1 to 3 of 3
Thread: Garage door in RO less than door width?
    Default Garage door in RO less than door width?
    I'm faced with a problem with narrow wall bracing in a wall with two 9' garage doors and a man door. To provide the required width of the end wall braced panels using the APA method, I will be left with less than 9' ROs for the 9' doors. It strikes me that this is no big deal - the door will be mounted behind the framing anyway (inside the garage). I'm talking about 3/4" on each side.
    Does that sound like a solution? I know I'll have to properly place the 2x6 perimiter band inside the framing for bracket attachment.
    'Course, there's always trimming 3/4 off the doors! But I don't know what material doors I'll be using yet.
    Thanks,
    Jonas
    Extreme DIY Homeowner Scuba_Dave's Avatar
    Jan 2009
    South of Boston, MA
    As long as you don't mind the looks
    3/4" missing from RO
    Then another 3/4" covered over bythe outside trim
    That means you are covering up ~1.5" of the door
    That may look weird
    I put my door on the side of the garage instead of the front to keep my 9' doors. I need the clearance with a truck
    DIY Handyman (not 4 hire)
    I have enough to do to my own house
    In the Trades AZ Contractor's Avatar
    Apr 2007
    Phoenix, AZ
    Quote Originally Posted by jrfiero View Post
    Don't worry about it. Its done that way all the time.
