Results 1 to 5 of 5
Thread: Method to keep irrigation pipe above lake floor
    Post Method to keep irrigation pipe above lake floor
    What do you think of using a floating "decoy" to keep the pipe above the floor of the lake to minimize debris? Anyone have any luck with this method?
    Thanks,
    Cory
    Moderator valveman's Avatar
    Mar 2006
    Lubbock, Texas
    I use floats for the pump or intake all the time. Keeps it up off the bottom, and doesn't let it skim from the top.
    Default What material is best for this type of float?
    I have no idea what type of material the buoys are made of (that my neighbors have). Any suggestions of material, type and where to get them?
    Thanks,
    Cory
    Mar 2006
    Lubbock, Texas
    We use floats made for boat docks. Usually long and skinny to hang a submersible under, like 4X1X1. I can get you a name if you can't find anything on a web search.
    Default floats
    ANYTHING that floats and has sufficient buoyancy to support your intake will work.
