I have a toilet waste line that was placed in preperation for the yet to be attached toilet flange. The vertical 3" pvc coming up to the hole where the flange will go is leaning at an angle of about 7 degrees off vertical since the plumber did not get the run below aligned perfectly with the hole. The horizontal run is about 1" offset.
Is this acceptable? Can a coupling, no hub, or gasketed flange be inserted w/ that much skew at the flange to vertical pipe connection safely?
There are so many close fitting connections in such a compact area, that I don't see any way to align the run better and replace that non straight vertical without cutting out and rebuilding a huge conglemeration of fittings. There is one section, the first horizontal downstream from the elbow under the toilet, where there is 4 and 5/8 inches of pvc pipe, but from there onward, there are about 8 fittings all within less than an inch of each other (a 1" tee from the sink plus ebows, then 5 fittings in a row bending towards/down into a wall). That 4 and 5/8 inches isn't enough to fit 2 opposing 22.5 degree elbows, which would be just about right to shift the line over 1". There is not enough play in the run to force it into alignment.
A gasketed closet flange seems it might allow enough play to be placed into the vertical pipe at a slight skew and there is the safety margin of it's extra length, though perfect gasket compression seems like it might be a concern. A standard coupling doesn't seem to allow enough play, and that or a no hub seem more likely to collect debris when skewed.
This seems a bit of a mess to me, but it passed rough in inspection. To be fair, it's an extremely tight space to work in, with only 2x10 joists, (studio apt bath above a 12' wide garage). The plumber who did this work is unresponsive/multi time no show, and I've pretty much given up on him. I need to get this ready, with the vertical below the flange cut off correctly, before I insulate and close in all the plumbing in this floor/ceiling.
Attached are some photos and a drawing, the last photo simply showing a gasket flange test fitted with the needed amount of skew.
Thank you for this marvelous forum! I've found it extremely helpful!
Bruce
Bruce
