Results 1 to 12 of 12
Thread: Water Softener Self installation
    DIY Junior Member chubyball's Avatar
    Dec 2006
    Default Water Softener Self installation
    Is it possible to install Water Softener by myself? Anyone here ever done it?
    Plumber jimbo's Avatar
    It will involve cutting in to your cold water supply pipe at a location such that all the house water, and NOT the water for the outside faucets, is softened. That will involve soldering to your copper pipes. Then you must route the drain tubing to a code-approved drain location.
    Almost everywhere in the country, you are ALLOWED to do this, AND you are REQUIRED to get a local permit.
    Quote Originally Posted by chubyball View Post
    I've been selling water treatment to DIYers for at least 6+ years and they install it per my very detailed instructions without problems. Or they hire a plumber.
    It is simple water line plumbing and in many instances you don't have to solder, you can use compression fittings or Shark Bite or similar types of fittings. Or you can learn to solder in about 20-30 minutes, I send everyone a link to a Windows movie that runs about 15 minutes and teaches how to solder. Or you can use corrugated flexible SS or copper tubing and not solder.
    I very rarely hear of a customer or a plumber they hire, getting a permit.
    Jul 2008
    S. Maine
    As with any alteration of the "potable" water supply, an understanding of cross connection and backflow are key elements in doing the job safely. Permits are required pretty much everywhere to do this type of work. In NH a license is required to do this kind of work. Improperly installed, the installation could lead to a multitude of problems.
    Default softener
    The biggest factor to be concerned with is making sure you get the water flowing through the softener in the correct direction, which may NOT be the easiest way to connect it to the existing water pipes.
    Quote Originally Posted by nhmaster View Post
    Yes I tell'em all that they shouldn't plumb the drain line from a sink etc. or the sewer line to the inlet or outlet of their softener. Or the drain line from the softener to their toilet....
    Did you mean to say that a homeowner there in NH must be licensed to do water line plumbing in their own homes?
    I'll have to tell the NH DIYers that call me and see what they say. I think they'll say "yeah right, and I'll quit speeding'n dumping my laundry water out back too".
    Jul 2008
    S. Maine
    Homeowners can install their own stuff but they still need a permit and inspection.
    DIY Junior Member Buckeyetech's Avatar
    Jul 2007
    In Ohio, you can install it yourself with no permits in my area.
    Jul 2008
    S. Maine
    Remind me not to have a glass of water in Ohio
    We do know that in MA, it is absolutely illegal for a homeowner to do even the smallest plumbing job.
    Yeah I feel bad about potentially selling to outlaws in the land of taxes and Kennedies but I don't want no claims of discrimination, and IIRC they all say they are hiring a plumber to install it....
    Really? Because I'm in Southern NH, on my own well, pulled my own permits, and never had a problem.
    -rick
