Hi Guys.
I just bought my first house as a foreclosure so I dont know much about whats down in my well but my pump failed the other day during a lightning storm and Im trying to pull it out.
It is a 50 foot well with 4" steel casing and poly pipe. I had a "pro" come out and take a look and he couldnt pull it out but he was just using his hands.
He gave up and I came out with a comealong and got it all attached to the poly pipe and cranked it a few times. The pipe came up a few inches but I cannot tell if it is the poly pipe stretching or if the pump is moving at all.
I was told that there is either mineral buildup in the casing or the pump could have swelled when it was struck by lightning.
This "professional" put a few small cups of dry acid? down the casing.
Now I read the label on this dry acid and it recommends something like 1 pound of the acid to 1 gallon of water in the well. Has anyone here had experience with some acids breaking up the deposits in the well? Any recommendations would be appreciated.
Also I have thought about running some galvanized pipe down to the top of the pump and beat it with a hammer hoping to dislodge it from its stuck position. Has anyone tried this either? anything that I should be careful with?
Also worst case senario lets say when i use this winch to pull it up and the poly pipe breaks or pops off the pump what would I do then?
