Combo ball valve/check valve for ejector pump...
hhcibtpaun
Pennsylvania
Hey everyone,
I am getting the parts together to finish up my basement plumbing. I am now at the point of getting the ejector pump and associated valves.
I am going with the Zoeller M267 pump and I need to get a check valve and ball valve. Originally I was going to get the zoeller check valve and a standard issue ball valve, then I found this:
This is about double what the separate pieces would be, so is it worth it? If any parts fail can they be replaced??? or do I have to replace the whole deal?
Any help would be appreciated.
Thanks...Mike
Redwood
That is a much better valve.
Most check valves give a helluva thump when the pump shuts off.
This one is quiet.
valves
If the ball valve fails you will have to cut it off the pipe and get a new one. Parts may or may not be available, so you might have to buy a new combo and use the parts from it if anything else goes bad.
