Gdunbar
- Messages
- 20
- Reaction score
- 0
- Points
- 0
Had plumbers remove old 2in cast iron p trap for a shower, and install a ABS 1.5in P trap for a tub/shower.
All he did was jackhammer around, snap cut the cast which broke all jagged at the lead coupler. He left about a lip ranging from .5in to 1 in protruding from the old Lead coupler. He then attached a Fernco type fitting with a metal sleeve onto the lip and then put in ABS P trap.
Now its all filled in, except a 9 x 12 box around it and I attached tub drain to test and it is leaking from the cast iron connection into the new Fernco sleeve connection.
How do you fix this? Is there some sealant product that you can glob around the fitting??
geoff
p.s. this drain goes right into main stack
geoff
