Yes.
If you are under the 2008 NEC then yes, you must connect to this with the proper clamp. Use a #4cu.
Yes, you must bond the metallic piping system in the house. Since it is not metallic where it goes underground you can make this connection to a clod water pipe anywhere accessible.
Again, use a #4cu for this bond.
If you make these connections NO other electrodes or rods are required.
