Results 1 to 10 of 10
Thread: unclogging well point
    Default unclogging well point
    I think I may have a clogged wellpoint. Any suggestions for unclogging it?? I have heard of using some type of acid. Any help would be greatly appreciated. Thank you.
    There are well cleaning chemicals made specifically for that, any old acid may damage your well materials. IIRC Johnson makes NuWell.
    Smile
    Thank you so much Gary, any idea where I can get this product?? I have searching on the net and can't find it. Have a great day.
    shenork
    Check with pump, plumbing or well supply houses or well drillers.
    I can't find it even on Johnson Screen's site. So here is another that I used to know a few years ago and planned on using for well cleaning/rehabilitation, after much research;
    http://www.coteychemical.com/quick.html
    Previous member
    Jul 2005
    Riverview, Fl.
    Junior Member ExpressWellService's Avatar
    Jun 2009
    SW Ontario
    Haha There a joke around here, when you use that stuff you will need a new well. Never had much luck with it
    Haha, next time someone should read and follow the directions.
    Well driller,pump repair. and septic installer Waterwelldude's Avatar
    Feb 2009
    Texas
    When we have a well that needs cleaning because of say, a calcium build up, or lots of iron.
    We have used it with very good success.
    Travis
    "I shall never surrender or retreat" -Col. William Travis
    Previous member
    Jul 2005
    Riverview, Fl.
    Me too. Many times.
    Haha They will also remove bacteria encrustations.
