advice on bulding up a shower base
jeffc
Journeyman plumber and Bacflow Assembly Tester
Kennewick, WA
Run gravity lines to a sanitary drain if grade permits.
If grade does not permit then...
Install an ejector pit.
If you have the space near the shower then install a pump pit. A recommendation is the Liberty 370 series. The package comes complete and is easy to install. The discharge line needs to enter the sewer system fron the top of the pipe
Redwood
I think you should sell your trailer and move into a condo. Problem solved!
DOHHHH! :eek:
If where the previous drain was connected was legal (although not done properly), then tapping in with a proper trap, vent, and arm should also be doable. Where did the greywater issue come up, and how does your jurisdiction define it?
Redwood
Dude, Lighten up
this is all in good fun
Jeff
Yep, It sure is...
jadnashua If where the previous drain was connected was legal (although not done properly), then tapping in with a proper trap, vent, and arm should also be doable. Where did the greywater issue come up, and how does your jurisdiction define it?
