Results 1 to 9 of 9
Thread: check valve placement
    DIY Member msgale's Avatar
    Sep 2006
    Default check valve placement
    can a one inch swing check valve be placed in a vertical pipe and still worK? Or do they have to be horizontal?
    It's for near-boiler piping, to prevent domestic hot water heater usage improperly getting hot water to the house hydronic system in summer
    A little more info would be required. There should not be any cross-coupling between hydronic and potable water. Do you have say a demand type system in your boiler you shut off for the summer and use a tank instead? I'd consider just using a valve(s) to shut one off and open the other.
    Check valves can (normally) go horizontal (properly oriented) or vertical. If this is for potable water, you'll need probably a bronze, SS, or plastic approved for potable water use. Being hot may create some other problems.
    Sep 2006
    this is for the water heated by the mod-con boiler in a hydronic system. Now, its a primary/secondary set of loops, one zone only.
    The revision is to add an indirect water heater. For summer use of the water heater, i need check valve to protect against boiler-heated water going thru the house radiators.
    none of this is potable water. the heated hot wster for human use is on a separate set of pipes
    Plunger/TurdPuncher kingsotall's Avatar
    Aug 2008
    Flagstaff, AZ Sitting on an upside down 5 gallon bucket next to the GO 68HD
    Indirect water heater. Check valve goes after DHW pump before the tee where the return from the sysytem goes into the boiler. On the verticle is fine with a swing check.
    Might want to wait for Thatguy, nhmaster or HJ to weigh in with their opinions.
    I just post cuz I like to see my avatar.
    Master Plumber nhmaster's Avatar
    Jul 2008
    S. Maine
    What you need is a flow check valve which is not like a regular swing or ball check in that it has a weighted gate. Check out www.taco-hvac.com What you probably want is a Taco 219.
    Sep 2006
    Default i can't find 219 in taco, is ther another name?
    tried the web site, no luck
    Sep 2006
    Default OK, found the 219...
    How is that different or better than a plain swing check valve?
    Jul 2008
    S. Maine
    The check in a standard swing check is not heavy enough to always stay closed against thermal migration. A flow check has a heavier check assembly.
    Sep 2006
    ok, sounds reasonable, thank you , all of you, for the info.
    I love this board
