Results 1 to 8 of 8
Thread: Shallow Well
    Default Shallow Well
    We have a very high water table here in the Midwest. It averages around 40" year round. Would this be a good candidate to dig a trench with a backhoe and drop in seepage tile or some kind of drain tile? I am looking for irrigation and to keep my pond topped off. Thanks!
    Previous member
    Jul 2005
    Riverview, Fl.
    Just because ground is wet doesn't mean it will produce an appreciable amount of water. Water veins are made in clean sand and gravel or rock, which the backhoe wouldn't penetrate anyway.
    Default Wet Ground?
    When I say 40", that is the typical depth of our water table. I can dig down to about 5' and I hit a very light gray sand. at this point water begins to fill the trench. Is this not enough to extract by some mechanical means?
    Previous member
    Jul 2005
    Riverview, Fl.
    If it's clean grey sand with no clay or just plain dirt mixed it, you may be digging into surface water vein. If you put a well point into that stuff deep enough, you may have a well. Just digging a hole isn't going to work because it will cave in faster than you can dig. Since you don't want sand in your water, a well point is the answer.
    Default Well point
    What kind of GPM can I expect out of a drive point?
    Previous member
    Jul 2005
    Riverview, Fl.
    From 0 to about 18 gpm. That's been my finding. If you have very coarse gravel, like pea gravel or bigger, you could expect (with the right screen) up to 25 gpm.
    Can you suggest a place to get these good points & screens? Thanks!!!
    Previous member
    Jul 2005
    Riverview, Fl.
    I have a few Stainless steel slotted screens I'll sell. They are the best you can get for driving into the ground.
