Results 1 to 7 of 7
Thread: Relocating baseboard heater (forced hot water)
    Default Relocating baseboard heater (forced hot water)
    I need to relocate my forced hot water baseboard heater to another area of my living room. The area is fairly close by, just need enough space to put in a sliding glass door. How difficult is this for a do it yourself project and what are some of the steps/items etc. that I need in order to do this successfully?
    Engineer jdkimes's Avatar
    Littleton, CO
    Not familiar w/ that but doesn't seem like it's anymore difficult than other plumbing projects. Turn off the hot water, drain, add pipe length, done.
    Anybody know?
    DIY Senior Member plumguy's Avatar
    Jul 2005
    MA
    Quote Originally Posted by jdkimes
    Anybody know?
    "doesn't seem like it's anymore difficult than other plumbing projects". Now that is what scares me more than anything else, and you have hundred plus posts Are you out here as opposed to the electrical sites because of plumbing's simplicity??
    Jul 2005
    Marin Co. Ca.
    Default tbabu
    boilers, circ. pumps, and controls are expensive hardware. even if you got lucky you may end up with air in system. not really a diy project
    Littleton, CO
    Found a that might help you decide whether to DIY or get a plumber
    Click here Hydronic
    Keep in mind it is currently along an outside wall because it is your cold wall. About to be even colder with a door installed. You may want to consider a way to keep the heat close to the door.
    Paul
    DIY Senior Member Cal's Avatar
    May 2005
    Northern Virginia
    Plumguy, I'm with you ! Anyone giving advice that easy about baseboard heat had better give up the ghost !
    Fella,if you've never had the true "JOY" that is dealing with an old hot water heat system and moving baseboard,,,,,,,,,,,CALL A PLUMBER !!
    Cal
