North Jersey
What is the magnitude of the pressure drop in a gas line that can be attributed to temperature change? I pressurized the line with air for a leak test. The pressure dropped from 17.5 psi to 17 psi over about three hours. I noticed the temperature of the attic, where about 2/3 of the line runs, dropped around 15 degrees during this time. If you're doing a 24 hour test, what kind of pressure change could be chalked up to temperature?
