Results 1 to 8 of 8
Thread: Pressure drop due to temperature change?
    DIY Senior Member Noth Jersey's Avatar
    Jan 2009
    Hopatcong, NJ
    Default Pressure drop due to temperature change?
    What is the magnitude of the pressure drop in a gas line that can be attributed to temperature change? I pressurized the line with air for a leak test. The pressure dropped from 17.5 psi to 17 psi over about three hours. I noticed the temperature of the attic, where about 2/3 of the line runs, dropped around 15 degrees during this time. If you're doing a 24 hour test, what kind of pressure change could be chalked up to temperature?
    Plumber jimbo's Avatar
    This pretty well sums it up:
    http://en.wikipedia.org/wiki/Ideal_gas_law
    The pertinent equation in this case is for contstant volume:
    P2= P1(T2/T1)
    Aug 2008
    Default nano plumbing
    And in laymens terms...
    I just post cuz I like to see my avatar.
    P1 is your starting pressure. Multiply it by the ratio of the new temperature divivided by the original temp. to get the new pressure P2..
    I have to double check what units the temp. must be stated in. It might need to be kelvin.
    edit: yes, temp. is in K. So, lets take an example:
    starting Temp. 80 Ending temp 65
    starting press. 15
    ending pressure = 15 X ( 291.98/299.81)
    ending pressure appro. 14.6 PSI
    note: I hope PSIG is the proper unit for pressure. Might it have to be PSIA?? I have to sort that one out!
    Default pressure
    One the temperature stabilizes, the pressure should also. That is why the inspector usually only checks it during a 15 minute period, assuming you have a very delicate gauge.
    Plumber Winslow's Avatar
    Dec 2005
    Hawaii
    I use a manometer to test gas lines. It is by far the best method. I use a mercury manometer to test rough piping (as per UPC) and water manometer to test final. It let's you know instantly if you have any leaks.
    Jan 2009
    Hopatcong, NJ
    I kept the line under pressure over weekend. After it bottomed out, it rose half a PSI by Monday morning, so I feel pretty confident I'll pass my inspection.
    I should have thought of using the manometer I bought for my HVAC projects. I was just using a 25 psi gauge with .5 psi increments, which is what the propane company and the inspector will look at.
    Default gauge
    Here, it has to be a 10 psi test using a 15 pound gauge with 1/10 psi graduations. Even a manometer will respond to the pressure variation from temperature changes.
