Results 1 to 3 of 3
Thread: Delayed Ignition
    Default Delayed Ignition
    I have a oil fired utica boiler that experience delayed starts intermittently.
    I've cleaned fully, replaced the air tube assembly (which include igniters and nozzle), and filter.
    It starts ok sometimes but at times starting is delayed causing smoke and a boom from to much oil being dumped in the chamber.
    Last time this happened (about 7 years ago), we replaced the transformer which fixed the problem.
    Is there somewhere else I should look or just replace the transformer?
    TIA
    Master Plumber nhmaster's Avatar
    Jul 2008
    S. Maine
    Transformer
    Electrodes
    Nozzle
    Primary & secondary air
    Draft
    Primary control
    Solenoid valve
    Oil Pump
    Pump coupling
    Wiring problems
    Voltage problem
    Combustion chamber
    End cone
    Nozzle line adjustment
    ijkl515
    Guest
    Smile Juicy Couture belts
    Juicy Couture belts 2008 - Designer swimsuits from Juicy Couture belts Click on any photo below to see more belts styles from that group. We Offer 2,500+ Charms. Explore juicy couture belts.
