Results 1 to 3 of 3
Thread: Tile to floor on tub surround?
    Question Tile to floor on tub surround?
    Two questions:
    1] should I run the tile of my tub surround down the edge of the tub right to the floor? Or just stop at the tub edge? Is there a right/wrong with this?
    2] And what about the top... should I go right to the ceiling? I was going to stop about 1 foot from the ceiling, just above the showerhead and leave a 1 foot band that would simply be painted.
    Lance
    Most of the time, it works better to tile to the floor, since there will often be a few drips here and there and tile handles it better.
    Tiling above the showerhead is a matter of preference. I tiled to the ceiling (and some actually tile the ceiling, too). Not because it is the right thing to do, but because I liked it in my situation. If your ceiling isn't level, it can be a pain. In my case, I was using granite tile, and made my own cove molding from 2" strips, with a back-bevel 45-degree. Since the tile was installed on the diagonal, it easily hides the height differences in my ceiling.
    Plunger/TurdPuncher kingsotall's Avatar
    Aug 2008
    Flagstaff, AZ Sitting on an upside down 5 gallon bucket next to the GO 68HD
    Have you posted pics of the work you did, Jim┐ If not, lets check it out! Your time to shine...
    When there are steamers they will tile the whole shower. Top to bottom.
    I just post cuz I like to see my avatar.
