Hello, I have been using this forum for info for a while but finally feel I need to join and post. We have a house that we bought about 2 years ago which has a 160ft well that had the pump replaced just prior to purchase. I don't know the reason for replacement but I have a guess. Since we moved in the pump has always made a lot of noise throughout the house(in the pipes). I have completely remodeled the house down to studs so I know the noise is not coming from loose pipes but actually transmitting from the well through all the pipes( a loud hum). The pump has always worked fine along with the press switch and tank. Other than the noise the biggest problem is that we get quite a bit of very fine sand in the water(if we fill our hot tub sand will cover almost the entire bottom by time it is full).
My question is whether the pump noise is caused by pumping so much sand which has ruined bearings even though it is only 2 yrs old. If so will something like the aquastream product that attaches to the pump pickup actually works to keep out sand without getting clogged down at the pump. My only other question is if maybe raising the pump would reduce sand pickup and if so how much do I move it?
I am a very capable technically oriented person but have little experience with wells. I do feel I have the means to pull my pump myself and can do all the electrical and plumbing work so any input will help.
