ABS foam core or solid ?
PeteB
If ABS pipe and fittings are used for draining hot water from a dishwasher is solid core or foam core more desirable? What is the difference between the two? Thanks for any advice.
PeteB
This is the first time I have used ABS. I assume the heavy duty stuff is solid. Does solid have a higher temp. rating?
NHmaster
S. Maine
I have seen foam core used on commercial dishwashers that looked like spaghetti after the 180 degree water hit it.
