Results 1 to 10 of 10
Thread: Water softener discharge line
Threaded View
    DIY Junior Member uuu1234's Avatar
    Jun 2009
    California
    Default Water softener discharge line
    Hi all,
    I'm trying to install a water softener in my garage, which apparently is pre plumbed for supply line, but not drain line.
    The fact that a toilet and a sink right above the water heater at second floor and a clean out on the opposite wall outside tell me there is a drain pipe in the wall. Unfortunatelly look like the pipe is right behind my water heater.
    So here is my first question: Without taking out the water heater and reinstall it back, can I open up drywall and tap water softener discharge into existing drain pipe OVER WATER HEATER? It will be 6-7 ft over the floor and 3 feet over water softener itself. Since water softener drain with pressure, I believe the height shouldn't be a problem, but I don't know if it break any plumbing code.
    My second question: From what I searched so far, I know I will need a p trap to tap into the line and an air gap for health concern. Do I need to worry about overflow since the dirty water can come from second floor and the pipe won't be sealed below it?
  1. Water Heater ATP discharge line - how far off ground outside
    By fortop in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-05-2012, 04:56 PM
  2. Water Well Line - Sediment Filter - Expansion Tank - Water Softener - H2O Htr. Order?
    By chuck b in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-09-2011, 05:21 PM
  3. Help with Water Softener Discharge Point
    By qpm in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-01-2010, 11:42 AM
  4. Water softener discharge line
    By uuu1234 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-04-2009, 05:01 PM
  5. Connect a new line to a water softener
    By marky in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-28-2008, 02:07 PM
