Thread: DWV Joining to Terracotta Pipe
    Default DWV Joining to Terracotta Pipe
    Could some one please help me as to joining DWV Toilet pipe to terracotta watse pipe.
    Default joint
    You have to have a "plain end" piece of pipe, not a bell and then use a Mission, or other brand" coupling with one side sized for "clay" pipe and the other bor the DWV, although you might have to use a bushing in the DWV side if your supplier does not have the proper sized reducing coupling.
    Jul 2005
    Marin Co. Ca.
    Default mel
    we need the pipe material type you are joining to terracotta !
    dwv is the plumbing application, not material type
    chances are it,s either cast iron,pvc, or abs
