Results 1 to 6 of 6
Thread: Rough estimate of the cost to switch from gas to electric
    DIY Junior Member chubyball's Avatar
    Dec 2006
    Default Rough estimate of the cost to switch from gas to electric
    I was thinking replacing my water heater to tankless is there a lot of cost for doing this?
    It will likely be expensive. You may need to get your entire electrical system upgraded to have enough power. Energy density to use a gas version is probably a better choice but, just replacing what you have with (maybe) a larger tank may end up far more ecconomical. Depends on what you are trying to accomplish.
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    1 Therm of energy can be had from approx. 100 cubic feet of natural gas or 29 kwh of elec heat.
    What are the rates in your area? I pay 16/kwh (=~$4.60/therm) and $1.10/therm of NG.
    DIY Member khayes's Avatar
    Oct 2005
    Alpharetta, GA.
    Thatguy - you have one creepy avatar!
    Aug 2008
    MD
    Quote Originally Posted by khayes View Post
    Yes, I got a bunch of photos from Germany that were taken all over the world.
    This one makes a good case for
    http://en.wikipedia.org/wiki/Endangerment
    on the part of the parents (if he/she has parents).
    Mechanical Engineer PatPro's Avatar
    Jun 2009
    Virginia Beach, Va
    Default Tankless system costs
    Assuming you have an electric tank type water heater now and you want to install a gas tankless system, you are probably looking at about $2,500.00 dollar range. You will need to extend your gas piping (and make sure you have enough capacity at your meter), provide venting for combustion air and the products of combustion, toss in a little bit of pipe work and lastly a bit of electrical work for the tankless unit controls/spark. You can find out more information at http://www.mechanicalengineeronline....er_Heaters.htm
    If the new unit will be electric, probably $1,500.00 if the panel is big enough to power the electric tankless system and about $2,500.00 if you need a sub-panel (service entrance needs to be verified).
    It is good that you are thinking of this before your tank type system quits.
