Results 1 to 8 of 8
Thread: Inspection Request for PEX
    Programmer mbauer's Avatar
    Jan 2009
    Dallas, TX
    Default Inspector requesting insulation for PEX
    The inspector is requesting that I insulate my attic and outside PEX runs. He is also requesting that I fill the holes in the top plate with spray foam.
    Does anyone know if the spray foam will be a problem where it comes in contact with the PEX?
    Can I just use regular polyethylene tubing with the PEX and use metal strapping to secure it?
    I'm using Wirsbo AquaPex by the way.
    Aug 2008
    The spray foam will be fine. But I guess a call to Uponor couldn't hurt matters.
    I just post cuz I like to see my avatar.
    I'm kind of surprised he is requesting foam. I would have thought he would want fireproof caulking.
    Aug 2008
    Fairfield Co.,Connecticut
    Quote Originally Posted by mbauer View Post
    Your best to ask the manufacturer about compatibility issues. Are you sure the inspector is allowing you to use foam and not intumescent (not sure about spelling) caulk?
    Dec 2007
    Quote Originally Posted by 99k View Post
    I think you may be right on that...
    http://www.fastenal.com/web/products...ex?sku=0217415
    Default foam
    Just regular foam here, because the wood is already flammable. Fireproofing is only for fire rated structures requiring non flammable materials.
    Knowing the other side of things, I like fire-resistant foam. A top plate, even a single one, will burn for a good 10-15 minutes before being compromised. Can you say that for regular foam or caulking?
    I consider myself an accomplished DIY'er. I don't know everything but help where I can. I'm not a pro, but like to think I'm professional.
    Jul 2008
    S. Maine
    The foam is not there to stop the fire. It is there to stop the chimney effect that will draw fire into the cavity. I would bet that most PEX manufacturers would tell you not to use a urethane foam product in contact with their pipe.
