Scuba_Dave
Extreme DIY Homeowner
I have a stream on my property
Last year I connected a pump as a test to fill my ponds
Water came out pretty slow, not a good fitting on intake
So this year I decided to dig a pit closer to the pond & my veggie garden
I barely dug down 20" & the pit filled with 12" of water
I figure if I did a 4x4 pit about 2' down I should have about 16" of water
Worst case I figure 12" & that would give me about 130g of water
I need to check the pump I have & see the ratings
It will be pumping about 31' & up about 5'
This is less distance then it was pumping last year
Pump may only do 70 gph with rise/run
I also want to use this to water the gardens
Thoughts?
Thoughts?
