Thread: Horizontal Vent Tee Orientation
    DIY Junior Member GoDillos's Avatar
    Jul 2005
    California
    Default Horizontal Vent Tee Orientation
    I have to tie 2 vents together. The best place to do this is when they are running horizontally in the space between floors. There they will meet at a right angle. Ideally, I would use a "vent tee" for this, right? However, I couldn't find one at the big box store.
    Can I use a san tee? These are dry vents. If I do use a san tee, how do I orient it? Here's a picture of how I think it should go:
    Does that work? Any help would be much appreciated.
    If the santee for the vent is six inches above the flood level, it will be fine.
    Default tee
    ANY tee would work there and the orientation is immaterial, although inspectors like to see them installed in the direction of flow as if air performed the same as water.
