Results 1 to 14 of 14
Thread: Stuck snake in Vent pipe
    DIY Junior Member Nurpo's Avatar
    May 2009
    Florida
    Default Stuck snake in Vent pipe
    Here it goes.
    In my second bathroom. Sink and toilet are backing up into the tub. The water drains slowly. I used a 30' power auger, in the tubs vent and drain with no luck. All so ran the power auger threw the toilet, no luck with that either. So I decided to use a Tape snake on the Vent from the roof. <--- Big mistake .
    The Snake is 3/4" wide by an 1/8" thick and has a pointed head that rounds off towards its back. Made it past the first 90 and that was it. It stopped shortly after that. and now it wont come back. Tried pulling with all my might, it just wont budge. Any suggestions on how to unstick it with out having to open the pipe where its stuck at? I've read threw the forums I saw that on cable augers the answer was to winch it. Will this work on a tape?
    Nov 2008
    Chicago, IL
    Some people with the hand snakes ram to hard trying to make the turns and blow the back of the turns off. With out being there I can not give you any good advice , but if you did leave the pipe. Its time to open up the floor and remove the hand rodder that way.
    Plunger/TurdPuncher kingsotall's Avatar
    Aug 2008
    Flagstaff, AZ Sitting on an upside down 5 gallon bucket next to the GO 68HD
    You got one of these stuckż
    I just post cuz I like to see my avatar.
    May 2009
    Florida
    Yeah thats pretty much it. The head is slightly different though.
    May 2009
    Florida
    Opened the wall and removed the copper incoming drain line from the sink, thought I'd get lucky and it would be stuck at that place. It indeed goes down to the slab and stuck in a 90 below the concrete. As SewerRatz suggest is breaking the slab apart my next course of action or is there another alternative?
    Thanks Guys for your opinions.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Default Stuck snake in vent pipe
    I would hire a professional plumber !
    That knows how to cut the tee and remove your snake and has the size and
    kind of snake to properly clear the drain blockage and put the pipes back
    the way they should be ! ! !
    MACPLUMB 777
    E-MAIL JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Default drain
    mistake #1. The vent was not the reason the drain was not working.
    #2. Flat tapes have a specific use, and seldom work, but the way you used it was not one of them.
    #3. cutting the pipe apart without knowing if that would cure the problem.
    Probably a few others, but you may be making the job more serious at each step you take.
    Aug 2008
    They did open one of these, didn't theyż
    Feb 2005
    Talking YOU NEED TO PULL HARDER with leverage...
    We have gotten snakes stuck before,
    you need to pull harder, and perhaps try to devise
    some sort of handle that you can grip with,
    perhaps some HEAVY DUTY vice grips FIRMLY attached to the tape right above the vent stack....
    then you need to figure our some way to get some good leverage
    against the vice grips with a pry bar....
    attempt to pry up from against the vent stack or the roof.....
    their is a very good chance that it might pop loose with the leverage.
    ....or the vice grips will slip....
    just dont fall backwards off the roof when it does finally break loose.....
    ( yes I have done this before)
    Plumber Cass's Avatar
    Nov 2005
    have you been trying to spin the tape while trying to remove it...
    Maybe enough 1" PVC with a 45 glued to it and slide it over the tape and down the vent as far as it will go and see if that will help get the tip into a different position...
    Default tape
    You have obviously NEVER tried to rotate a 3/4" flat tape, unless it is a very long straight pipe.
    Feb 2005
    Talking hey now......
    hey now, their is no reason to get criticle of Cass and his recommendation.... LOL...
    Semi retired master plumber freeflow's Avatar
    Aug 2009
    alabama
    Default stuck
    Try pouring a qt of motor oil down stack and twist it around with the vice grips and JERK HARD
    Default Worked for me
    I tightened the set screw as tight as I could as near the clean out as I could and picked the whole machine up and used it like a slide hammer. 4 bangs and the snake was FREE!! I tried the come-a-long, that didn't work.
