Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
Thread: lap top no power
  1. #16
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    Quote Originally Posted by Redwood View Post
    A 3 Lb. hammer properly applied can cure anything...
    At that point now!
  2. #17
    Default laptop
    I would not invest in a new battery for it until I knew it was going to work.
  3. #18
    Dec 2007
    There is an internal battery that keeps things going like the clock etc.
    It is a button type battery mounted on one of the boards...
    When this dies the laptop will not start even with a power cord attached and a good battery...
    Many laptops will run fine off the power cord with a dead battery...
  4. #19
    Aug 2007
    Cincinnati OH
    Yep,tried that too,It is now scrap.
    Thanks for info.
  5. #20
    Aug 2007
    Cincinnati OH
    Quote Originally Posted by rsgoldrsmoney View Post
    can that spam!
  6. #21
    Done, plus, I wanted to tell you something Clay about my laptop hiberating at will and staying in that mode to the point where I had to reboot.
    Well, mine is still under warranty and I called tech support and I had to type in a command prompt because for some unknown reason, my laptop was not recognizing it anymore.
    This is what I typed in, if this happens to you,
    (where you do a command prompt, go to, run and type 1CO, hit enter then a black box will open and type in this command:
    powerCFG-DEVICEQUERY wake_from_any
    then, hit enter.
  7. #22
    Aug 2007
    Cincinnati OH
    Thanks Cookie,I donated it to crayons to computers which is a local program
    that helps teachers in our area with supplies and more. I hope they get
    something out of it.
  8. #23
    Well, it did it again. Mine might be joining yours.
