Please post pictures
My mum and dad have a cast iron bath with a rigid over flow and a copper trap from either just before or just after ww2.
We tried to removed the waste and overflow to fit a sprung combined waste and over flow. the over flow was disconnected no problem and the new one fitted but the waste will not come out! I dunno what to do now
The nut underneath was cut off as it was ceased from about 60+ years of not being used. but even though its all flush the waste just will not come out.
Help please!!!!!!
We have no idea what you did or are trying to do, because the drain and overflow are a combination, so if you change one part you would normally do the whole thing at the same time.
But I do like the title of the thread.![]()
I just post cuz I like to see my avatar.
Not all are combined. ours is from just after world war 2 are has a rigid overflow that terminates outside of the building like in the picture on the left in this link.
http://www.showerdoctor.com/removing_cast-iron_bath.php
And it is being replaced with a new type like this.
http://www.victorianplumbing.co.uk/s...21-p-2376.html
We got around the problem using a dremmel to cut away the brass locknut and prized it away from the threads. if I can find them il take some pictures of how bad they were. but here are the old overflows and the copper trap.
That olds trap rocks! I've never seen a trap drain on the side like that.
