Howdy. Hope I can find some help here.
I have a 12VDC solar system that runs a 240VAC deep well pump (12 volts from battery kicked up to 120 AC by an inverter and then to 240 with a transformer).
My problem is that the points on the pressure switch burn out every couple months. I have the pressure pump controlling the 120 line that goes to the transformer. I'm using just one wire on one side of the pump.
As the points burn, the resistance causes a huge extra demand on my batteries -- sometimes running from 130 amps DC (normal) to 400+ amps.
All the wiring seems OK, but I must be getting arcing at the points.
Thanks for any help.
Josey
Josey
