Results 1 to 9 of 9
Thread: Pex Methods
    DIY Junior Member jafriede's Avatar
    Mar 2009
    Iowa
    Default Pex Methods
    I am going to be installing a water softener in a house I'm buying and will need to re-route some things. I am thinking of using Pex. I found a video on YouTube that showed 6 different methods of putting on ends. The two I'm considering are the crimp ring or the banding clamp. Which is the easiest/reliable? Is there any reason not to get the supplies from Lowes? They carry Zurn products.
    DIY Member wallskev's Avatar
    May 2009
    North Carolina,USA
    Default See other post
    I use only the brass fittings and Clamp rings. Does require a tool ( About $100) but have had 0 leeks
    See other post :
    PEX fastener terms -compression ring, crimp,clamp...
    Kevin
    My preference is Wirsbo. The tool is not cheap. Pex has memory. With a clamp, it is always trying to loosen. With the compression/expansion Wirsbo uses, it is always trying to make the joint tigher. Do either one right, and it should be sound, but having the extra layer of actually using the memory properties just makes me feel better.
    Plunger/TurdPuncher kingsotall's Avatar
    Aug 2008
    Flagstaff, AZ Sitting on an upside down 5 gallon bucket next to the GO 68HD
    Jim, you are a sage amongst fools.
    I just post cuz I like to see my avatar.
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    A crimp ring system from a reliable manufacturer has never given me problems. Having said that, the wisbo system is definitely a premium system with a premium price.
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
    Radon Contractor and Water Treatment 99k's Avatar
    Aug 2008
    Fairfield Co.,Connecticut
    The cost of materials and a tool is insignificant if you are a DIY and just cutout the plumbing contractor cost, therefore, go with the best!! Wirsbo is the best choice ... ProPress for the Pro (who can justify a 2K tool).
    If you're a DIY, consider the Flair-It fittings. No tools required. It's a nut and cone set up. The nut slides over the pipe, the fitting is rocked into the pipe and the nut is threaded back over the fitting/pipe. It's that easy. Just hand tighten the nut until you can't go any further. If it leaks, tighten a little more with a Flair-It wrench. The fitting has a flaring cone that applies pressure to the ID of the pipe, while the double threaded nut threads onto both the pipe and the fitting, creating pressure against the OD of the pipe. Flair-It fittings are best used with PEX-a, which is a little softer than PEX-b.
    Master Plumber nhmaster's Avatar
    Jul 2008
    S. Maine
    Quote Originally Posted by OK?Guy View Post
    Flare it fittings are CRAP CRAP CRAPPITY CRAP.
    Aug 2008
    No tools required. If it leaks, tighten a little more with a Flair-It wrench.
    huh¿
