Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
Thread: Kitchen sink leaking to outside wall
  1. #16
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Exclamation Kitchen sink leaking
    NO IT'S NOT A GLUE PROBLEM OR ANYTHING ELSE,
    IT IS A PIPE PROBLEM ! ! SEE THE FOLLOWING LINK ! ! !
    http://www.abspipes.com/
    AND ALSO THIS LINK http://www.abspipes.com/id.html
    THE ONLY WAY TO FIX IS TO CUT OUT AND REPLACE !
    DO NOT REPEAT DO NOT USE ANY GLUE ON ANY OF THE OLD PIPES ONLY USE METAL JACKETED PIPE COUPLINGS !
    YOU CAN HOWEVER GLUE TOGETHER ANY NEW PIPES AND FITTINGS
    AS A CALIF, PLUMBING CONTRACTOR I WAS VERY INVOLVED IN FIXING THESE TYPE
    OF PIPE PROBLEMS IN THE LATE 80'S AND EARLY 90'S IN THE SO. CALIF. AREA BUT THIS PROBLEM WAS WIDESPREAD THOUGH OUT CALIF,
    MACPLUMB 777
    E-MAIL JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
  2. #17
    Quote Originally Posted by Redwood View Post
    It does indeed sound like a pipe problem inside the wall. Things need to be opened up to find it.
    Agreed 100% - Go big or go home,
    Tear the wall open as Jerry and the others say
    [B]
    You Should Assume Everything I say Is A Complete Lie - Thank You ~
  3. #18
    Plunger/TurdPuncher kingsotall's Avatar
    Aug 2008
    Flagstaff, AZ Sitting on an upside down 5 gallon bucket next to the GO 68HD
    Did you not see the pics after Redwoods post you quoted¿
    I just post cuz I like to see my avatar.
  4. #19
    Default leak
    It is not a bad joint, it is the cracked pipe I mentioned originally.
  5. #20
    Aug 2007
    Exclamation Kitchen drain leaking
    Yes i know redwoods post,
    did you check the links i posted ? ?
    That is exactly the symptoms i was talking about !
    As soon as i saw the pictures of the problem i knew that confirmed what
    i posted !
    MACPLUMB 777
  6. #21
    Aug 2007
    Default Kitchen sink drain
    The problem is the glue continues to dissolve the pipe because of the chemical make up of the way the pipe is formed ! !
    That is why i posted do not glue to old pipe, ! !
    I have worked on many thousands of these leaks, ever thing from 11/2" vent pipe up to 3" sewer pipe leaks that flooded the family room,
    when ever the upstairs toilet was flushed,
    i worked for the developer co, where we had to go back and correct these
    problems also note on the links i posted he can get payed what it costs
    to correct the problems and any resulting damage like his kitchen sink areas
    calif. Lic. Contractor since jan. 1989
    MACPLUMB 777
  7. #22
    Aug 2008
    OH! Sorry fellas... Yes! Some apprectice got lazy and through the pipe off the box van where it was strapped and cracked the pipe once it hit the asphalt! When he tried to blame the asphalt, his journeymen plumber says, "Yes, it is the ass' fault. Agreed!" Wonder how I know these things¿
  8. #23
    DIY Junior Member Fisherman's Avatar
    May 2009
    Caulifornia
    Thanks fellas, for all of your comments and information. I found a legitimate plumber friend at church who is willing to help me do the repair. He suggested using what's called a "No-hub coupling" between the old pipe and the new pipe. So, now I'm off to make up my shopping list, and then it's off to Home Depot. I *really* appreciate all you guys. I'll post pictures of the repair when I'm finished.
    Cheers!
    I hate plumbing, that's why I'm here.
