Results 1 to 2 of 2
Thread: Vibration in Water Softener when using inground sprinkler
    Default Vibration in Water Softener when using inground sprinkler
    Ideas, please.
    I have in inground sprinkler system, that comes off of the water supply to the house ahead of my Culligan 2 tank (Mark 100?) softener. ONLY when I use the sprinkler, NOT with other water use, I am getting a severe vibration in the water line, which seems to be coming from the softener. IT GOES AWAY WHEN I BYPASS THE SOFTENER!
    Not sure whether to call Culligan, a plumber, or what the problem might be. Your help and ideas are appreciated!
    DIY Senior Member Wet_Boots's Avatar
    Mar 2007
    Metro NYC
    Is there a pressure tank on your water heater? You might be getting a reverse flow. A check valve could be added.
