Thread: Hydrant supply
    DIY Junior Member
    May 2009
    midwest
    Default Hydrant supply
    Hello,this is my first post and I will try to describe here what I am trying to do.We have been biulding a new home on a piece of property we have owned for quite a long time.To start out with we have a existing well drilled some ten years ago.We have operated it in the past turning a hydrant on and then the electric power(no pressure tank).Now I would like to hook the house up to the well.I have had two well contractors look at it and give proposals.After reading here it looks like to have it work properly the line needs to go up to the house and come back to the hydrants?Pressre tank will be at the house.Neither of the contractors mentioned this.Also the hydrants are in very different directions from the well.The well is 207 ft deep water table at 120 ft and it has a 2 hp pump.My question is should I be pointing this out to them or do they possibly have a different way of making the hydrants work?Thanks 50cal
    DIY Junior Member
    May 2009
    midwest
    does anyone have a comment on this ?
    Previous member
    Jul 2005
    Riverview, Fl.
    I would imagine the pipe going to the house would be big enough to let water come backward from the tank to feed the hydrants. Just don't install any check valves anywhere. You have one in the pump and that's all you need anyway.
    bob...
    Moderator valveman's Avatar
    Mar 2006
    They will probably just tee the line at the well. One side of the tee goes to the house and tank, the other side to the hydrants. It would work much better and require a much smaller tank if a Cycle Stop Valve were installed at the well before the tee. Yeah and no extra check valves.
