Results 1 to 2 of 2
Thread: Washer Drain Vent
    DIY Junior Member vman's Avatar
    Jan 2008
    Massachusetts
    Default Washer Drain Vent
    I'm placing a laundry area under the stairs of my 3 fam. The house waste drain is about 4-5 feet away. The stack is about 20 feet away. For venting of the DWV I was thinking of taping into the stack vent in the attic, running it down to the basement along side the chimney and then horizontally along the basement ceiling (slightly pitched). Any opinions if this will help the draining of the washer and meet "code".
    Default vent
    From your description, and if it is done exactly that way, it appears that it would. But we could only be sure if we were there to see exactly what you plan to do.
