That adjustment is probably a manual backpressure regulator. It's used to in the case of the manual regulator to get the prime. Once primed, it's opened up all the way. It's only used on a deep well system. On a shallow well system like yours, it's left open all the time.
A jet pump can make a max of 60 psi in most cases. I don't know what your referring to using the term head. Head is vertical feet. Pressure is head X.433.
bob...
