Results 1 to 11 of 11
Thread: 3rd FL bathroom accident
    Angry 3rd FL bathroom accident
    I recently purchased a house with a 3rd floor toilet that had a slow leak. As such, we had shut off the water to it as we don't use that floor of the house very often.
    Today, I decided to take a closer look at it since I had finished some other more important projects. The leak was coming from the supply line where it meets the tank. Without thinking, I began to tighten the connection when the supply line broke loose.
    Brief chaos ensued and I was able to turn off the water. I grabbed a bunch of bath towels and mopped up as much water as possible. Unfortunately, enough water was released that there is some slight dripping down to the 2nd floor. I have opened windows and placed a fan and dehumidifier in the bathroom.
    My question is, will the house be ok drying out from that much water using the fan and dehumidifier? If not, what is my next step?
    It should be okay...sustained dampness causes problems; a single dowsing that didn't soak everything might cause some paint damage, but probably won't make any other long-term problem.
    Dec 2007
    I agree!
    Just what I was hoping to hear, thanks so much guys!
    Nov 2008
    Chicago, IL
    Quote Originally Posted by tbankhead View Post
    Three out of five plumbers agree.. there is no harm with a short term soaking.
    Plumber jimbo's Avatar
    If the ceiling below got wet, then after it dries out, it may show a brownish stain. Kilz or Bin123 will fix that.
    Dec 2007
    If you don't use kilz or binz the stain will bleed through the new paint.
    Plunger/TurdPuncher kingsotall's Avatar
    Aug 2008
    Flagstaff, AZ Sitting on an upside down 5 gallon bucket next to the GO 68HD
    Sounds like you were tightening a flood safe supply.
    I just post cuz I like to see my avatar.
    Default line
    Floodsafes break at the stop, not at the tank. he had a supply with a cracked ballcock connection and tightening it finished it off, making it a broken ballcock connection.
    Aug 2008
    Oh, yeah!
    In the Trades kordts's Avatar
    Oct 2005
    exurban Chicago
    My 3rd floor bathroom accidents are a little different than this kind.
