Results 1 to 5 of 5
Thread: Replace Duct vs. Manual Damper
    DIY Junior Member
    Feb 2009
    Chicago, IL
    Default Replace Duct vs. Manual Damper
    I am remodeling my home, and I am adding more insulation to the walls and sealing all the air leaks. Basically, some rooms get more air than other rooms. I am wondering if it is possible to install a manual damper inside the duct or is it better to replace the branch duct with a smaller one.
    For example, in the bathroom on the main floor, the current duct is a 6" round duct, which delivers about 100 CFM. However, the room is only 40 sq. feet and really only needs 30CFM, or a 4" round duct.
    I plan on having a variable speed furnace installed that is sized correctly, because the current unit is a single stage and it basically dumps about half of the rated CFM into the basement, which makes it feel like an oven in the winter and a freezer in the summer.
    In the Trades jnaas2's Avatar
    Mar 2009
    Evansville In
    When they install a new furnance have this installed then you can balance the airflow, they must be installed on all supply lines off the main trunk
    DIY Junior Member
    Feb 2009
    Chicago, IL
    Quote Originally Posted by jnaas2 View Post
    Thanks!!! Seems like a much cheaper solution.
    Default air flow
    The cheapest solution would be to close the dampers on the registers so they let less air through.
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    While maintaining reasonable air flow thru the HX.
