Results 1 to 2 of 2
Thread: Pot filler install
    DIY Senior Member rockycmt's Avatar
    Nov 2007
    New York
    Default Pot filler install
    I am installing a cold water pot filler. It requires a "1 / 2 Inch IPS/NPT threaded stub-out". Anyone have a picture of this? I have the wall open so it will be an easy install. Just not clear on what this is.
    Plunger/TurdPuncher kingsotall's Avatar
    Aug 2008
    Flagstaff, AZ Sitting on an upside down 5 gallon bucket next to the GO 68HD
    You need a drop ear secured to some blocking in the wall with 1/2" copper or PEX supplying it. Depth of drop ear shouldn't be too critical. Just need to match up a nipple when the wall is up and tile or whatever the backsplash is is done. Then you just find the right length nipple for your pot filler connection to screw on to flush with the tile. Leave an 8" nipple capped in the drop ear for the time being while the wall is being completed for work to be done around it.
    I just post cuz I like to see my avatar.
