Thread: FWIW, Checking a 4-way switch
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Default FWIW, Checking a 4-way switch
    Label a switch terminal "1".
    Find a terminal that has continuity to 1 and label it "2". Label the other two terminals 3 and 4 and check that they have continuity and
    that there is no continuity between 1 & 3.
    Flip the switch lever:
    if there is now continuity between 1 and 3 there should also be between 2 & 4 and none between 1 & 2.
    or
    if there is now continuity between 1 and 4 there should also be between 2 & 3 and none between 1 & 2.
    Default 4 way switch
    Or look at the back of the switch to see which terminals are marked "Line 1" and which are "Line 2".
    Aug 2008
    MD
    From all the 4-way switch trouble people are having I thought the terminals were unlabelled and uncolored.
