Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 71
Thread: Troubleshooting two 3-way switch setups
  1. #16
    DIY Junior Member Donwe's Avatar
    Nov 2009
    Bend, Oregon
    --- s === s === s --- o
  2. #17
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Quote Originally Posted by Donwe View Post
    Your schematic leaves something to be desired, but I think a traveler for sw 3 is missing
    or the 4-way is wired incorrectly or is bad.
    BTW, 'on' is not defined for 3-ways and 4-ways; that's why they are not labelled like other switches.
  3. #18
    Default wires
    All it takes is for the common and a traveler to be interchanged and the circuitry will not operate properly. Mixing "line 1/A and 2/B" on the four way can also cause weird operation.
  4. #19
    Nov 2009
    Bend, Oregon
    Thats what it was, once I isolated the traveler pairs and re-connected everything works just fine, Thank you!
  5. #20
    DIY Junior Member alth's Avatar
    Dec 2009
    Canada
    Default Trouble with 3way Switch!
    Hi there hope you can help:
    Will a 3 way switch with the following configuration work for my stairs to basement, and if it will how can I fix it:
    Live Feed
    l
    l
    Switch #1 ---- Switch #2------ Light # 2
    l
    l
    l
    Light #1
    When Switch #1 is on and Switch #2 is off Light #1 works but Light #2 does not
    When Switch #1 is on and Switch #2 is switched Light #1 turns off and Light #2 turns on
    When Switch #1 is off and Switch #2 is switched nothing happens
    Thanks for the help!
  6. #21
    Aug 2008
    MD
    Are both lights supposed to go on and off together?
  7. #22
    Yes, that's called a California or coast 3 way...
    This an illegal and very dangerous wiring method and should never be undertaken.
  8. #23
    Dec 2009
    Canada
    Yep, Both lights should go on and off together.
    and Ill give that a shot Billy Bob. another problem is that I cant change the wiring to Light #1 as the wall was completely finished by the previous owner, will this make a difference?
  9. #24
    Quote Originally Posted by alth View Post
    You would just need access to the wire going to that light.
    And of course be able to wire everything else like in the diagram above. This is an illegal and very dangerous wiring method and should never be undertaken
    Or wire it in the traditional manner. Many ways to do this...
  10. #25
    Aug 2008
    MD
    Quote Originally Posted by Billy_Bob View Post
    Do you then say you have 3 travelers instead of 2?
  11. #26
    Dec 2009
    Canada
    Default 3-Way
    Off the top of my head I think I do have 3 travellers... Will update when I get home
  12. #27
    Dec 2009
    Canada
    Default Issue Resolved
    Thanks for your help everybody... the california circuit was the way to go
    should something go wrong your little a$$ will be in a very tight situation.
    Last edited by jwelectric; 08-23-2011 at 09:03 AM. Reason: what you have is illegal
  13. #28
    DIY Junior Member timmer62's Avatar
    Mar 2010
    greenville, sc
    Default 3-way switch troubleshooting
    S1 down, s2 down, light off
    S1 up, s2 down, light off
    S1 down, s2 up, light off
    S1 up, s2 up, light on
    any ideas how to resolve?
    thanks
  14. #29
    DIY Junior Member mgabbard's Avatar
    Nov 2010
    Chicago, IL
    Default Another 3-way case for you
    Quote Originally Posted by Thatguy View Post
    This assumes two travelers between the switches.
    Assign each switch a number.
    With switch #1 & switch #2 down, light is on or off?
    With #1 up & #2 down, light is on or off?
    With #1 down and #2 up, light is on or off?
    With #1 & #2 up, light is on or off?
    In principle, with the answers filled in, the problem(s) can be pinpointed.
    Test cases welcome. . .
    Hi there,
    I have a relatively new home (10 years old) and am replacing the standard rocker switches / receptacles in my house with decorator models room by room. Everything has been easy so far (3-ways, 4-ways, 2-ways, etc) , but am having trouble figuring out what's up with one 3-way in one of my rooms. The old switches I marked the common and the travellers, and on the new decorator switches I connected the commons to the common pole and the 2 travellers to the traveller poles. But the switches are behaving strange.
    #1 down, #2 down - lights are on
    #1 up, #2 down - lights are on
    #1 down, #2 up - lights are off
    #1 up, #2 up - lights are on
    So when #1 is up - no matter what #2 is (up or down) it still completes the circuit. And when #2 is down, no matter what #1 is (up or down) it still completes the circuit as well. Very strange. It's like they are wired in parallel.
    These are brand new switches and I have jiggled the wiring to make sure there are no shorts in the wires.
    Any guidance you can give you be most helpful. I've been looking at this one too long and need a fresh set of eyes.
    ...M
  15. #30
    Electrical Contractor Jim Port's Avatar
    Aug 2009
    Maryland
    Regardless of UP or DOWN a 3 way will reverse the current condition of OFF or ON. Your setup is working properly.
  1. Troubleshooting our well. Help appreciated
    By Dfrank in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-16-2012, 05:41 PM
  2. Furnace Troubleshooting Help
    By mdr in forum HVAC Heating & Cooling
    Last Post: 01-24-2010, 11:54 AM
  3. Takagi Jr Troubleshooting
    By duff in forum Tankless Water Heater Forum
    Last Post: 01-15-2010, 08:44 PM
  4. PRV troubleshooting...
    By Runs with bison in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-03-2009, 01:16 PM
  5. Troubleshooting
    By davewest in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-24-2009, 11:51 AM
