Results 1 to 5 of 5
Thread: Pump Pressure - Problem or Normal
    Question Pump Pressure - Problem or Normal
    I have a 2 inch screened well approximatel 20 ft down. 6-8 feet of water in the pipe. Prime is great. I'm testing with a 1/2 hp Wayne Shallow well jet pump. Input is 2 inch galv to the union, then 1 1/4 galv into the pump. On my output I have a 3/4 T, pressure gage on one side, hose bib on the other. Before I open my hose bib pressure is 70 psi dead nuts. Immediately after I open the bib and the water runs thru a wash machine hose to a bucket, the pressure drops to 20psi. Is this normal or should my pressure remain in the 60's? I get about 5 gals of water in 35 seconds. Is 1/2 hp enough pump? I have a chance to buy a brand new 1hp Wayne for $75, and I will if it would help.
    I'm trying to run a 7 zone system with 5 heads per zone. One zone at a time.
    Any feedback would be appreciated.
    Previous member
    Jul 2005
    Riverview, Fl.
    Wayne is a low quality pump. 10 gallons per minute for any 1/2hp pump is a lot of water and it won't be at a very high pressure.
    First of all, how much water will your 2" well produce?
    Second, how many gallons per minute do these 5 heads per zone need?
    bob...
    I had a 2hp sprinkling pump on it and I don't think the well could keep up with the demand the pump was asking for. So I had the 1/2hp shallow jet in my garage and I hooked it up.
    How can I tell how much water the well can produce? It was roughly 9-10 gallons in a minutes time with the 1/2hp. I imagine the bigger the pump the more water...
    Please advise.
    Or you could say the faster the 2" well goes dry, which burns up pumps.
    Previous member
    Jul 2005
    Riverview, Fl.
    For some reason homeowners have a problem with test pumping a well to see just how much it will produce. This is the only way you will know what the well is good for. It beats the hell out of buying a two horse pump that can produce 80 gallons per minute and putting it on a two inch well that can only produce 15 gpm.
    Size the well first, then size a pump to match it.
