Results 1 to 7 of 7
Thread: Issues changing to Florescent Bulbs
    DIY Junior Member noreast's Avatar
    Dec 2008
    Long Island, NY
    Default Issues changing to Florescent Bulbs
    Hello All!
    So in an effort to cut down on my exorbitant electric bill, we picked up a bunch of energy saving bulbs to replace our incandescent bulbs.
    When swapping them out of a set of 4 high-hats, only two will light while the other two will not. Yet when I have 4 incandescent bulbs they all work.
    Does anyone know what might be causing this?
    Thanks in advance for any advice.
    George
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    If the voltage to the lamps is 120v ± 5% or ±10% then almost certainly the bulbs are faulty.
    Elec. usage of ~9000 kwh/yr is normal while 30,000 is higher than 95% of homes.
    Maybe the base of the CFL is hitting the socket and not screwing in all the way.
    DIY Senior Member SteveW's Avatar
    Feb 2005
    Omaha, NE
    Are the bulbs on a dimmer circuit?
    Most fluorescents will not work well, if at all, with a dimmer, photocell, or a lighted toggle switch.
    If "high hat" means recessed cans, flourescents will have reduced life due to heat, and the bulb manufacturers recommend that 23 watt and up not be used at all. They should NOT be installed base up.
    Extreme DIY Homeowner Scuba_Dave's Avatar
    Jan 2009
    South of Boston, MA
    I only have 4 CFL bulbs that dim
    They have to specifically state they will dim
    And they do not dim as well as incandescents
    I have CFL's on lighted toggle switches in 3 different places & have not had a problem
    I also have CFL's installed in 3 overhead fans - single bulb
    These are enclosed in a glass fixture
    I only have 13w bulbs in these - all that will fit
    What do you mean by high hat? Do you have a pic?
    I have CFL's installed thru-out the house without a problem
    Inside & outside all year long
    I also have over 200 in my Christmas display
    DIY Handyman (not 4 hire)
    I have enough to do to my own house
    Feb 2005
    Omaha, NE
    So George - don't keep us in suspenders - did anyone say something helpful in your quest to get your CFLs working?
