Results 1 to 14 of 14
Thread: Basic wax-ring question
    Default Basic wax-ring question
    Having been to Home Depot last night, there are a plethora of wax rings:
    - your basic standard wax ring.
    - the oversized wax ring.
    - the reinforced wax ring with some plastic actually in the wax.
    - the waxless wax ring.
    - the extended wax ring.
    The guy at home depot said to get the oversized reinforced wax ring because it is designed for flanges that are installed properly AND for flanges that are a bit low (1/4" to 1").
    Any thoughts?
    Dec 2007
    On a properly installed closet flange I use a regular wax ring.
    Infact I rarely use anything else, seeing as in the case of an improperly installed closet flange I usually make corrective measures to the flange...
    Nov 2008
    Chicago, IL
    Take all that wax and toss it and get your hands on a 4 lB tub of Sta put plumbers putty.
    Quote Originally Posted by bradahkimo View Post
    Any thoughts?
    One Answer: Marketing
    As REDWOOD says above, The normal is fine
    [B]
    You Should Assume Everything I say Is A Complete Lie - Thank You ~
    Avoid those with the funnel...they tend to cause more problems than they create. If you don't get things perfectly aligned, you can end up with that funnel collapsing and giving you all sorts of grief. If the flange is low, best to raise it or use flange extenders, but a lot of people have success with a thicker ring.
    Aug 2008
    I can't seem to find the thicker rings without the horn lately.
    I just post cuz I like to see my avatar.
    Default horn
    After you use a utility knife on the funnel, NONE of them have a funnel.
    DIY Junior Member Tanker's Avatar
    May 2009
    NY
    I've been using the one with the funnel for years thinking that it's the better one. What kind of problems does the funnel cause? So after adding a ceramic tile floor just a regular or thick wax ring without the funnel is the best bet?
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    The funnel causes a restriction,use the thick wax or as Mr Ratz said sta put
    putty,used them both and they work fine,but with sta put you have form
    the ring your self.
    I think you must understand that when we say the wax rings with funnels cause problems, it should not be take that every use will create a problem. The real point is, you don't get any benefit from one, but you do get a potential for a problem. We sometimes tend to overstate things.
    Default rings
    If you read the box, the ones with the fiber "reinforcment" usually state that they are for use with "wall hung" toilets.
    May 2009
    NY
    I don't see the thick rings without the funnel in local stores by me, can it be pulled or cut out? Maybe a supply house would carry them.
    Aug 2008
    And I quote,
    Depending on the diameter of the drain pipe and how well you center the toilet on the flange, you could cause the funnel to compress or distort and actually close up. If you install the toilet properly with the wax, and your flange is where it should be, it will last until you decide to replace the toilet.
