Results 1 to 11 of 11
Thread: Shower Valve needs replacement?
    Default Shower Valve needs replacement?
    Here's my dilemma. When I turn my shower on to full hot, it's fine. But it's too hot, so I need to back it down a little. When I turn the lever down, instead of just having to back it off a liitle, I have to bach it off almost all the way before there's any change in the water temp. Then when it finally changes I have to turn it back up a ways to get the right temp. In other words, turning the lever does not produce a direct corelation in the cange of the temp. It didn't used to be this way. Also, when I finally have the temp set where I want it, and my wife turns on the water in her sink, the shower water gets scalding hot and when she turns it off the shower stays hot. Again, it didn't used to be this way.
    Anyway, I took it apart and everything looks ok. I can't imagine that replacing anything is going to solve the problem, but I don't know what will. I'm open to any suggesstions.
    BarryName:  DSCN6245.jpg
    In the first pic, the piece you see still inside the body is the balancing spool. Grab it out and replace it.
    OK, I'll try that, thanks. Any idea who the mfg is?
    Plunger/TurdPuncher kingsotall's Avatar
    Aug 2008
    Flagstaff, AZ Sitting on an upside down 5 gallon bucket next to the GO 68HD
    This website might help you. Keep in mind that the parts numbers listed are theirs. A supply house in your city would not know their (Arpny's) number. It may help you find the mfg. is all.
    I just post cuz I like to see my avatar.
    Nov 2008
    Chicago, IL
    Its a Price Pfister Body Guard Faucet 0X8 Series
    Here is the parts break down for you. http://a-archer.net/images/ppbodyguard.pdf
    Last edited by SewerRatz; 05-03-2009 at 10:00 PM. Reason: Added parts breakdown link
    Default faucet
    Call 1-800-PFAUCET and tell the customer service person what you need, and they will send it to you.
    Nov 2008
    Chicago, IL
    They do a life time warranty on parts like Moen? If so thats good to know. Thanks HJ for the phone number, I programed it into my cell.
    Plumber Cass's Avatar
    Nov 2005
    I ran into this exact valve with Kohler PB trim on it....it was a slick way to deceive a home buyer...
    Nov 2008
    Chicago, IL
    Quote Originally Posted by Cass View Post
    I had a job at a condo we been doing work at for 30+ years. The lady wanted lots of plumbing repairs done including fixing a leak on her two handle tub and shower faucet. So I explained to her we need to come out a day or so before the scheduled day so we can ensure we have the right parts. So we went their Saturday morning, and looked things over and the trim she had on the faucet was American Standard, so after making a parts list for all her other concerns we posted a notice to the building the water will be off Monday morning.
    We returned, turned off the water removed the handles and the stems. Turns out it was not American Standard, it was similar to a Moen but with distinct differences. So we repaired all her other concerns and explained to her that the trim was misleading and we have to come back the next day. She was so *****-off with us saying we where hacks and had no idea what we where doing. The maintenance guy at the association calmed her down and explained to her to the best of his ability that the trim is misleading and for us to carry every repair part for every faucet out there we would need to drive a semi-trailer. Well turned out the faucet was a Valley.
    You guys are FANTASTIC! I just went down to the local plumbing supply store and got a new balancing spool, installed it, and it works great!
    Many thanks to all who responded. I really appreciate the quick, accurate diagnosis, and part identification. It's great to have it working properly again.
    --Barry
    Nov 2008
    Chicago, IL
    I am glad all has worked out ofr you.
